1693TA
Dozer has taken to "making oil" again in the crankcase. The front seals on the Roosa-Master DC pump have been replaced twice so don't know what is going on there. The pump was rebuilt by a reputable shop in south central IL a few years ago and has been back off the engine twice since then for this same problem. I'm going to pull it again sending it in to a shop I know and trust quite well as seemingly something has been missed? I know the dual umbrella seals have been replaced using the proper tool for installation so kind of lost as to a cause right now.
I always check oil cold before engine start and the level was right on "full". I then noticed the stick being about a pint high over the "full" mark after engine idling for just about an hour of warming for fluids change. Will get this addressed before progressing further. Tractor runs, drives, up and downshifts smartly, turns, and tracks tension up just fine so hoping this is a simple problem to be followed by a good routine service. The brakes do not grab and are even side to side upon application. I did notice a seepage oil leak in the transmission shifting quadrant which will require some access panels removal to isolate. Not a drip or run, just seepage at this time but will get it addressed regardless.
After service, a good pressure washing is in order. Cabbaging onto an idea from a friend there are probably going to be side curtains made to shield the engine and direct some air blast into the operator compartment for cold weather operation.
