cat 385
wow,good job iron horse.
It would look like an Elephants foot about 5' in diameter , i wonder if it would work .
and another for all you operators, TRACK WEAR is less when travelling in forward. I just laugh at the guys who are lazy and swing around so they can pull the levers towards them to travel forward for long distances. appereantly, they have not been instructed or are not paying the bill on the undercarriage repairs. there is a reason the tracks are placed on a machine a certain way.
It would work BUT would it cost more than the wear on the undercarriage it would save :beerchug
The other is an oscillating front axle on a wheel loader the same as the rear axle but with a ram on each side of the front axle . When you want to make a straight cut across a slope or run a drain off of a road or a 1000 other reasons you could tilt the whole machine to get the bucket/blade/forks etc level .
This is the type of Wheel Loader i was refering too in my original question , for the above ground use that i mentioned . Does anyone who manufactures THESE type of loaders do one with a leveling option ?
IS there though??on an Excavator forward is where you are facing,ya I know forward is really when the sprokets are in the back,but on a dozer the spokets are on the back because of the engine/tranny layout,,.........right??? I am not disagreeing but think about it... for the most part a dozer travels in reverse as much as it travels forward. unless you turn around to return back to the start of the push,( which we all know we dont).
The answer maybe some sort of mechanical lock for normal loader work with it being released when you want to level the machine.
Rn'R.
I just saw a thread in the mini exc. section that brought up a good question. With the mini's having a blade, would it be acceptable to use the blade to have something to push against? That would put you working over the drives. I guess the answer would depend on the how extreme the situation is, and if it was a last resort or not.
To reopen this can of worms
To reopen this can of worms the blade on the Kubuto exc is so far out in front, when trenching I dig over the track motors. ( do we have a smiley in the ducked position with his hands over his head ) No No NO I said ducked as in ducked down to avoid flying missiles.
