Different backhoe swing designs
Discussion in 'Tractor/Loader/Backhoes' started by hammerdwn20, Feb 28, 2010.
  1. hammerdwn20
    hammerdwn20 Well-Known Member
    Feb 18, 2008
    227
    pipeline
    pa
    I have a small Case loader and would like to build a backhoe for it in the summer. Yesterday i was playing around with the conventional 2 cylinder design and some plywood to get the geometry right for 180*. Ive got it pretty close but it does take up quite a bit of space. Are there other designs that are compact and still allow for 180*? I figured You guys have used almost every machine ever made and designs outside of the US.
    Here a couple pictures.
  2. Phil
    Phil Senior Member
    May 2, 2005
    1,067
    retired operator and mechanic
    Southeastern Ontario
    Have you tried going to the different dealers that sell compacts, for ideas? Lots of Kubota hoe attachments at the local dealer here. One was so small I think I could almost lift it. I have seen pictures at the local Princess Auto store of a chap who made one. Phil:)
  3. hammerdwn20
    Feb 18, 2008
    227
    pipeline
    pa
    the small kubotas like the bx25 and similar compacts dont swing 180*. ill just have to keep playing with wood until i get it right.
  4. Phil
    Phil Senior Member
    May 2, 2005
    1,067
    I looked at some Kioti's today. They are made in Korea and look like a Kubota. The CK series with the KB2475 and KB2465 hoe is designed to swing 180deg. I have the brochure here showing the specs. I see the swing cylinders are laid out like the Case 580 backhoes, side by side.
    I've seen several swing cylinder designs, like the Ford model with the chain connecting 2 single acting cylinders, or the old MF hoes with the swing motor. I think the International hoes were different again in their design, but I can't remember exactly how they work. The very early Case backhoe used 2 cylinders that really stuck out at an angle. I saw an old Fordson Major once that used a wire cable connected to a cylinder up front. Phil:)
  5. fpgm04
    fpgm04 Well-Known Member
    Jan 1, 2010
    214
    USA
    The 2 cylinder swing geometries that I have seen are “over-center” in design in order to get 180 degree swing. The swing cylinders will over-center by about 1”+ and is usually driven by the mechanics of the geometry, although I think some older machines actually had a special swing valve and physical valve linkage to the swingtower to over-center hydraulically.
    Good luck in your project!
  6. hammerdwn20
    Feb 18, 2008
    227
    pipeline
    pa
    Thats the way it worked out in when i did it in plywood. I had a 1/2" of "over travel" when swung to the extremes. ive got to see if i can jam the cylinders on either side of the differential to get this design to work.
