terex herder
I have a plastic diesel tank with about 250 gallon capacity on a combine. There is a molded brass exit fitting that is weeping between the brass and plastic. I have room to install a steel plate larger than the brass fitting and tighten it against the plastic. The brass part is hex shaped, about 1 1/2" across flats. I have plenty of room for a 2 1/2 diameter piece to seal around the brass. My go-to would be an o-ring to seal against the plastic of the tank. I am wondering if there is a conformal gasket material that would be a better choice than an o-ring.
