thepumpguysc
- Joined
- Mar 18, 2010
- Messages
- 7,555
- Location
- Sunny South Carolina
- Occupation
- Master Inj.Pump rebuilder
You "might" be tempted to try to get the seal out yourself using various methods.. DONT DO IT.
That baby is in there TIGHT & you'll end up gouging the aluminum hsg or the dr. shaft..
You better hope the shop has the special tool to replace JUST THE SEAL or you WILL get some grief over the seal replacement.. for just the reasons I mentioned above.
Its a cone shaped tool that's threaded on the OUTSIDE.. you slide it over the drive shaft & push it into the rubber sealing surface & screw it into the rubber.. Theres a center screw that you tighten against the end of the dr. shaft & it pops the seal out.. its pretty slick.. & dam near impossible w/o it..
