oarwhat
Like the title says did Detroit make a straight 8-71? Not a V. My buddy says he's looking at a boat with them in it. I've never heard of one. Thanks
Near as I know... No, but with Detroit Diesel, you never know. More than likely its a 6-71 inline.Like the title says did Detroit make a straight 8-71? Not a V. My buddy says he's looking at a boat with them in it. I've never heard of one. Thanks
8-268, but I think perhaps it would look a bit bigger than the 71 series.....
Is it possible to mount two 4-71s end to end? I would think it is.
The 16V-71 is two 8V-71s mounted flywheel to flywheel so I suppose it is possible. One would be reverse rotation. Don't know why one would though.
Your memory is failing you Don. The 3512 & 3516 are both single-block engines with a single crank, although the 3516 does have two joined camshafts on each side. You might be thinking of the 3524 which was the original engine used in the 797, it was basically two 3512s coupled together.CAT 3500 series work like that as I recall, nose to nose with a dampener coupling between. The 3516's for sure, and I think the 12's.
Not really or at least the ones I worked on. A more accurate discription would be nose to nose. Those were two specially designed V8 blocks bolted together and the crankshaft was actually two sections bolted together. There were two sets of timing gears driving a total of four camshafts. Two blowers one driven off each end of the engine. But only one governor with linkage connecting all four injector racks. One water pump and one oil pump and four 4-71 heads with some special fittings to connect the fuel and water passages between them.
I never saw one in person but have seen some pictures of 24V-71 engines, same idea but using 12V-71 blocks modified to do the same. Not sure if they were regular production on a limited/experimental design.
Pretty much correct, although the old type cam no longer exists there is now a Reman Upgrade-to-New option (your old cam as a Core and a guaranteed new cam in exchange) as well, so 12 Part Numbers rather than 16. Somewhere I have a photo of a 3516 that failed a piston skirt and not only managed to break both camshafts on that side of the engine but split the block from top to bottom as well. Happy daze .......I do remember the camshafts as I recall there were four separate part numbers and between new, reman, and old and new TYPE you had sixteen possibles to sort and get in the right corners. Or I could have dreamt that too, lol.
