Deutz FL2912 injection pump problems
1948 ford custom
I have a Deutz FL2 912 engine in an Atlas Copco compressor which will not pump fuel has been sitting for a while. Do the pimps stick over a long period of time?
funwithfuel
Will county Illinois
Mechanic
Probably air locked from long term storage. Prime your fuel system up to the injector nozzles. Those thi gs are too reliable to just quit.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If u have the 2 cyl in-line pump, remove the side cover and work the stop lever.. the insides should move freely right to left..
If it doesn’t, bump the engine over while working the stop lever to try to free up the dry pumping plungers..
Open up the lines AT THE INJECTORS to let any air trapped inside.. When it starts spitting fuel, close them up..
Good luck..
