No, no. Your desired height is on the tag of the Individual pumps. It should be the number that varies between them. Each pump is different. So, for example, if your pump says like 6-7000 you divide that by 100 which comes back to 60 or 70 mm. That is your desired installed height. That is dictated by your pump ID tag. You subtract your actual measured height from desired and shim accordingly.
Yes, I know that nobody does a good job of explaining this.
