Deutz Bf4M1011f
Terryz
jeffersonville, ny
I have Deutz BF4M1011F engine that I need to find the heigth of the pistons above the block. The Deutz manual calls for a special service tool to set up and measure the height to get the right head gasket; one of three. Anyone have the poorman's tools, a straight edge and feeler gauge to get a measurement. Thanks, Terry
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
Personally I cant say, I havent done it.. BUT, A straight edge & feeler gauge sounds good to me.. as long as all your checking is piston height from the deck..
A feeler gauge costs about 3-5.00 & anything that's straight will work good enough, it doesn't necessarily have to be "exactly" factory straight.
But like I said, I haven't done it..
tool_king
new jersey
road mechanic owner
If you look on your old gasket there will be notches cut into in the shape of a V it will be 1,2 or 3 that will tell you which one needs to be put back .Did you have head milled or just replacing gasket
Terryz
jeffersonville, ny
The old gasket has 2 notches. The head is off because the rings are wore out. This engine was apart at some point in its life and I want to measure for myself before reassembling.I have a deutz shop manual; looking for a parts manual; haven't been able to find anything online. deutz controls acess very tight. not much in the way of aftermarket parts.
tool_king
new jersey
road mechanic owner
Terry what is your serial number of your engine .I can look them up on Deutz.
Terryz
jeffersonville, ny
Engine SER # 263545 I need part #'s for .2mm rod brgs, piston & ring kits, Ring sets; I'm not sure which I need yet. head gasket 1 & 2 notch numbers. the piston height dimensions are close to upper limit on 1 notch & bottom limit on 2 notches. I will wait until I get pistons back in before ordering head gasket. Which way would you go? Also part # for valve guides; the head has 3 guides that that are 5mm higher than the others; possibly newer updated part, also can you identify the type of silicone Deutz uses. It is a very strong black silicone , it costs $90.00 for a tube Thanks, Terry
tool_king
new jersey
road mechanic owner
for tool king. additional parts needed , valve stem seals and 1 45 degree intake valve
Terry for some reason the Deutz site is not showing the part numbers . I am going to try this again .
65specialk
Gasburg Va. 24857
My Duetz jumped time because the timing pulley was somehow bent during rebuild And didn’t notice it. It hit the valves and bent most pushrods. I replaced pulley, belt ,tightener and push rods. I did a compression test and it’s low at 135 lbs. Could this have bent the valves on All 4 cylinders? I was told it is not an interference head. What should it have for compression?
ALsun35
edmonton alberta
did you end up pulling the head and checking for bent valves? im running into a similar scenario and i might just have the first deutz ever with bent valves it seems, every single thing ive read says theyve never seen it.
65specialk
Gasburg Va. 24857
I am going to do a leak down test tomorrow to see if any valves are leaking. The camshaft pulley was bent causing it too jump timing. I installed a new pulley, belt and tensioner. When I started smoke was coming off the belt. Note ! The new tensioner has to be pushed away from you. I pulled it towards me and the pulley was hitting a bolt head. Jumped timing again.
ALsun35
edmonton alberta
what compression test adapter are you using? Im waiting for the one i ordered here the
im quite certain ive got bent valves, im reluctant to just pull the head at this moment, even though im going to have to, but id like to get my compression numbers first to have a baseline to go off.
65specialk
Gasburg Va. 24857
I have a leak down tester. Not sure the brand. But I also have a diesel compression tester. I used the glow plug adapter and adapted it to the leak down tester. I bought the compression tester at Harbour freight for about $30.
ALsun35
edmonton alberta
can you send the part number of the kit that worked? Is it the threaded longer piece? havent seen any ones that look like theyd work with the duetz injectors besides the one i ordered, ive got the f4m1011
65specialk
Gasburg Va. 24857
Duetz head gaskets
65specialk
Gasburg Va. 24857
I checked my motor today after 4 exhaust pushrods bent. When it was running it didn’t sound right. I think it was off a tooth on the belt. When I changed the belt the back side was looser. After reading the manual in detail I read to pin the cam and the crank First. Then it said to loosen the bolt retaining the cam pulley That way the pulley can center and new belt is tight on both sides. Then retighten the cam pinch bolt. I didn’t do this the first time and I believe it was the problem.
Note: I did a leak down test first on all and no valves were leaking.
