Determining CAT blade trunnion thickness?
LCA078
Austin, TX
Are there any places where I can look up the thickness or ball diameter of a Cat dozer blade trunnion? I haven't seen drawings or specs for these types of parts but that doesn't mean they don't exist. This is the main trunnion bolted to the undercarriage. Specially trying to figure out a D6T trunnion ball diameter.
LCA078
Austin, TX
I didn't think they were still making D6Ts but I don't follow the new stuff so maybe I'm just out of touch. Good idea...there's a dealer not too far out of the way from me. No idea if they have one just sitting around. And I don't think they would have a trunnion in stock but again, I can check.
Oxbow
Idaho
I have a D6T I could measure, but it is VPAT and inside mounts. I assume you want outside trunnions?
LCA078
Austin, TX
By the way, I'm not seeing how to measure the diameter if the blade was attached. Am I missing a simple way to determine the diameter when it's covered by the bearing caps?
Oxbow
Idaho
Could take a cap off, but it won't be exact with the wear.
Oxbow
Idaho
I can try looking it up on SIS if you have a VIN number. I'm not sure if dimensions are included anywhere though.
LCA078
Austin, TX
I don't have a specific VIN but I went to Ritchie Bros and found a D6T with a full serial number
CAT00D6TCNDY00387. When I put it SIS, nothing comes up. I'm assuming I'm not supposed to put the whole number in but I can't get anything to pop up.
Joe H
Utah
Couple of Cat pages from here------> https://duckduckgo.com/?t=ffab&q=cat+trunion+ball+dimensions&ia=web
https://parts.cat.com/en/catcorp/7J-5131 Trunnion Size: 88.9 mm (3.50 in)
Compatible Models for part number 7J-5131​
TRACK-TYPE TRACTOR​
D6H XL D7R D4C III D6H XR D6T XW D6T LGP D3B D3C D7G D7H D6R III D4C II D4B D5H XL D6T XL D5C III D7R SERIES D6 D5 D7 D6GC D8N D4C D6H II D5R2 D5C D6R STD D3C II D6XE D7R LGP D5R XL D6 XE D7R II D5R LGP D6N LGP D6R XL D7G2 D6N XL D6R D6T D6M D6N D6R LGP D6R II D7R XR D6H D3C III​
https://parts.cat.com/en/catcorp/4J-1641 this one is
Specifications for part number 4J-1641​
Units of Measure
  • Material: Steel
  • Outside Diameter (in): 3.50, 3.44 (Spherical)
  • Length (in): 5.98
Too late Cmark knew the answer.
Joe H
LCA078
Austin, TX
Thanks, Cmark- that's the trunnion I'm trying to "measure" without actually seeing the machine in person. I'm assuming all the info is in SIS? If so how do I find it?
LCA078
Austin, TX
btw- SIS appears to be acting up on my side. I'm getting a lot of weird results and a lot of hang ups so maybe that's why I couldn't find any useful information earlier. I'll try again in the morning. Thanks again for the part number- I'll keep playing with it on my side.
LCA078
Austin, TX
So..... wow. I was finally able to get SIS working on my side this morning and tried the Similar Parts Search.
Again- wow. I never knew that feature existed. Cmark- you just opened up a new world of SIS for me. I'm still playing with it and I can tell it will be an huge source of info. Thank you.
Cmark
Hey. Just doing my job
