DrJim
- Joined
- Feb 19, 2011
- Messages
- 172
- Location
- Oak Ridge TN
- Occupation
- General Dentist, including Implant Restorations
:BangheadMy JD 5425 (green) tractor has some great features. Ah, but the flaws. The fuel tank is a generous 30-something gallons ( Good!) but the tank is plastic. When they manufacture the tanks, I'm guessing they drill, ream, or otherwise do the final shaping on the various holes (fittings) in the tank. The black shavings plug the dinky in-line pre-filter that runs under the tractor--it's about the size of your typical lawn tractor filter. To change that filter, JD says to remove the fuel line and drain the tank first. Yeah, right. How 'bout some needle-nose vise grips with some rubber tubing over the jaws as a pinch valve. The darn filter is so small that most anything will plug it.
When we first got the tractor, it ran great. . . until it didn't. Had it hauled to the dealer, and it took them half a day to realize that their was a pre-filter under the tractor--it wasn't shown in their service manuals nor in the owner's manual. When they figured it out, yes, it was fully plugged with black plastic shavings.
My tank has a drain plug--yes, a plug, not a petcock. The owner's manual says "loosen to drain the water", but by the time you figure out it's not a hollow bolt with a drain feature, the plug bolt is out and the hole is spewing diesel fuel all over you.
The real PITA: The fuel filter on this particular tractor has a drain (yeah, I know, most diesels do). The manual says "loosen and let drain until the all the water is out of the (clear) bowl". But the thing goes "glug, glug. glug". If you drain the fuel filter water/sediment bowl, you'll have to purge the air.
First, loosen the screw on the filter. It's plastic with an o-ring, and it quickly comes apart. Only costs $ 0.99, but you don't happen to have an extra, do you, and you're 6o miles from the dealer. Pump the plunger on the filter until no more bubbles come out, then tighten the now shredded plastic bleed screw. Think you're done? Just getting started.
Now you have to go to the other side of the tractor and loosen a flare nut on a fuel line, and then loosen a hex plug on the side of the fuel pump (this one is steel, and it _is_ hollow, like a banjo bolt. Yes, that's the factory prescribed procedure. Pump the plunger on the top of the fuel filter housing until no more bubbles come out of the bolt on the fuel pump. Hold the plunger down while you first tighten the bolt on the fuel pump, then tighten the nut on the fuel line flare fitting. Wait--how are you gonna do that? The fuel pump is on the other side of the tractor from the filter housing. How are you gonna hold the plunger down while you close the open fittings?
So, this either takes two people or you have to live with some air in the system. This sure doesn't encourage frequent draining of the fuel tank or fuel filter.
