Deere CT332 Won't Start
mountainlake
mn
sawmill operator
Get yourself a set of Deka 20' 2 gauge solid copper jumper cables and you wont have a problem jumping anything. Not cheap around $80. Steve
Gofigger
Manitoba Canada
Part time CE Operator !!
MoCat. Having the same issue but need some help when you are talking about "jumper cables" what cables are referring to? Appreciate the helpful
MoCat
Missouri
Hi Gofigger. Sorry to hear about your situation. When I spoke of "jumper cables" I meant a set of booster or jumper cables that have the large clips on each end that are used for jump starting a weak or dead battery in one vehicle with the healthy battery from another vehicle. The cables that I was trying to jump start my CT332 with were a light (maybe 8 gauge wire) pair and just couldn't conduct the amperage needed to start it. Like mountainlake said, I really needed something like a 2 gauge heavy duty booster cable to be able to jump start it. I eventually got mine running by buying a new battery, setting it on a makeshift table right next to the old battery in the machine, and then connecting the new battery directly to the existing battery terminals on the machine. I don't have any electricity in my barn or else I would have simply tried to charge the old battery while it was still in the machine.
RODBUILDER
Ill.
Look - you said you're having a problem with the glow plug circuit - right? Every time you hit the key with a good GP fuse oit blows - right? Well then, why don't you replace the glow plug solenoid?
1. There's no such thing as a glow plug "shorting out" It is NOT possible! They're like light bulbs - they BLOW!!!
2. Stop the skid loader here for a minute, though! If a solenoid coil burns up it CAN short out to the outside of the case!!! The primary circuit on a solenoid isn't fused to anything!!
3. Replace the glow plug solenoid and see what ya' have. If you look at it, I'll bey ya' it looks just like a 1970's $15 Ford starter solenoid!!!! But Bamby Deere will want 4 times that for it!
If the solenoid replacement doesn't fix it, it's time for a trip to the Deere store!!! $$$$$$$$$$$$$$$$$$$
MoCat
Missouri
Rodbuilder - Hey thanks for your advice about the glow plug and solenoid. What's weird is after I got it running, I've not had any further problems with the glow plug fuse. But, if I get some free time, I will take a look at the glow plug and the solenoid just to inspect their condition. I hear ya about how highly Bamby Deere thinks of its parts and changes accordingly for them ... always wants a whole lot of these things = $$$$.
Gofigger
Manitoba Canada
Moscato. Thanks for clarifying for me. That is what I thought but wanted to make sure. I am having similar issue with my 322 so posted under new thread to hopefully get some tips
