earthscratcher
i would like to buy a used rotobec log grapple and build fixed ears to pin to the stick or quick coupler so it does not swing around like its normally used.would this be hard on the rotate housing, it would be used for boulder placement on retaining walls.what would i need to do to switch from rotate to clamping action, it has one set of aux hydraulic controls on right joystick control, could i bring up a electric control solenoid switch to the joystick to switch from grapple to rotate, how would you do it ???
