Deere 755c 2 front idler removal.
Oliver182
Iowa
Trying to get the guide plates/side deals off the front idler. The outer plate has 4 bolts that go through that broke and seems only way I’m going to get the broke parts out is to remove it and get to the back side. What holds the side assembly onto the round axle the front idler has? Picture attached.
Oliver182
Iowa
Ok I appreciate it. Which one of these is the bolt you need to take off and any hints on driving it out? Thanks
Oliver182
Iowa
Ok just so I’m on same page. You mean running a punch past the threads and beating on it or threading a junk bolt in to engage the threads and beating on the bolt?
Dave Neubert
Monroe NC
Dave Neubert
Monroe NC
either way if you thread it in make sure it is threaded all the way in
