Blstr88
Ive posted here a few times in my search for a mini excavator, finally purchased one a few months back. I got it on my property right before the hard freeze/winter set in so other than moving a few small boulders and some logs it otherwise got tucked away under a lean-to and has been sitting. With spring coming I wanted to start a post here and gather some info about maintenance/use.
Mostly Im just looking for suggestions on maintenance things I should go through it before starting to work it this spring. It's a 2006 Deere 50D with 1900 hours. The company I bought it from buys these up, does some basic repairs/maintenance as needed and resells. It has a brand new thumb, tracks appear (to my un-trained eye) so be in good useable shape. Nothing stands out to me as needing immediate repair.
I figured to start:
1. Oil & filter change
2. Hydraulic oil filter change
3. Fuel filter change
4. Go through and grease all the fittings
5. Grease the turn bearing
Anything else you would suggest I look into? I'd like to get all the filters/fluids I need ordered in the next week or so, and get it moved up to my garage sometime in mid-March and by April 1 have it all serviced and ready to go. It'll be used entirely on my own propertly (no business use) mostly for light land clearing and the odd job moving logs, rocks, etc. Overall I think it will live a fairly easy life on my property and stored under cover/maintained.
Does anyone know how to disable to moving alarm? Anytime I move the machine forward or back it beeps...theres a button to push to silence but if I stop even for a second and start moving again I need to re-press the button. I realize thats probably a good safety feature on job sites but this will be used on my property only with nobody around, I'd like to turn that off if possible.
I'm going to purchase one of the online manuals for the machine as well. Any tips/advise would be appreciated!
I figured to start:
