I'm helping a friend of mine with a John Deere 450C Dozer. He bought it, knowing that the transmission case was cracked, but had gotten such a good deal he couldn't turn down. He has found a complete transmission, to do a swap, but looking at the shop manual pictures, the tracks and the track frame are removed.
Can a person pull the transmission case, and final drive assembly all in one piece, then remove the final drives.
Or does the final drives go thorough the frame rails to the transmission.
Im aware of all the other stuff a person has to pull to get at the transmission, but looking for the easiest way to swap out the transmission.
Id appreciate any advice on this operation, as I've never done it before, and knowing that this is a common problem, someone out there must have found an easy way to do it.
