JGS
I have a leaking loader dump cylinder on a 2005 Deere 410G. I'm having difficulties disassembling the cylinder. I have the repair manual. For some reason the actual disassembly of the rod from the barrel is not included. The rod guide is not your typical threaded into the barrel. The problem that I'm running into is the rod guide is retained by an outer and inner wire retaining snap ring. The external was easy to remove. But how do you release the inner snap ring between the rod guide and barrel? Thanks for any insight you can provide!
