Austin9159
Bought this machine a little while back, had to tear the hyd system down to replace the pump and clean all the lines out. Runs and operates good for the most part. Issue I’m having in when it’s cold it drives good but when it gets hot it starts to not want to pull correctly. I’ll push the joystick forward and it doesn’t move them let off and goes for a second. It’s usable but not enjoyable. It gets much worse when the high flow is on, because I’ll try and barely go forward and it lunges then slows, lunges then slows. It’s like the solenoids go wide open then back off or the high flow is back feeding?. I tried to calibrate it but it fails every time, no codes or errors, just says fwd calibration fail. I’ve checked the drive solenoids and all are within spec. Anything else to check or is this machine going to need a drive pump as well?
