Deere 330 LC
1466IH
prairie du rocher, il
Does anyone know the part #'s for the adapter cables to go from EDL V2 or 3 to the 4 blade diag plug on this machine? Have a melted wiring harness and have repaired harness since they are NLA but need to check a few things with computer.
mg2361
Pennsylvania
Equipment Mechanic
You do not use the EDL with an LC machine. You plug the cable directly to the usb port (through a usb/serial adapter). Do note, there is still the chance Service Advisor might not communicate with the machine. Most times it has, but occasionally it will not. MPDr, or in your case DrZX is the preferred tool, however I do not know what cables you use with DrZX..
1466IH
Thank you very much
