1000hills
I have a 2010 Deere 323D track Skidsteer with the common hard starting issue that also appears to have a lot of blowby. I’m suspecting cracked rings because I’m fairly certain someone used either in the past. (machine showed up with the air filter cover off and the filter element falling out). However it runs fine if you can manage to get it started.
I’ve also read on here that injector washers and slipped cams can cause low compression and blowby. I haven’t done a compression test yet or pulled the head, but how would I diagnose the injector or cam issues?
