beanfarmer71355
Machine has given ZERO issues, ever. One morning this week was pushing a pile of brush and when I went to back up it felt like a brake dragging, but not fully applied. Got out of the spot I was in and crawled underneath. Machine is a powershift
The connector for the park brake coil (the middle one of 3 in that area) was unplugged. I plugged it back in
Got on machine, was still sluggish, moved a few feet then smoke out of underneath and it was locked (park brake applied)
Oil level is fine. Changed sensor on top park brake. The machine does want to go forward and reverse. I then threaded down the two bolts that force the brake to disengage. They are run down until I broke one. But brake doesn't release.
I am thinking this thing came apart internally and is simply not disengaging. Thoughts on this? Can I tear it apart and remove the brake, run machine without, and fix this winter when slow?
Help....
Help....
