Recently purchased a D9H 90V and used it 4-5hrs here on the place with no problems at all, it run the way it’s supposed to. I pulled it in the shop to put new brass bushings and seals in the forward/reverse and 1-2-3 gear shafts in the top of the tranny housing, changed all the fluids/filters and cleaned the screens and also pulled to two small plugs on the bottom of the transmission cooler. It’s back together but won’t pull while in gear. The shaft between the torque and transmission is spinning but no movement fwd or rev. The only change I made was putting 50w instead of 30w in the tranny because I had a barrel handy and was planning on another fluid change soon because it set for some time. There is pressure to the pump and filter housing because I removed the plugs to get the air out. Could the thicker tranny oil not allow pressure to build and reach the top of the tranny transfer gears or is there something I’m overlooking?
