D7G keeps blowing torque converter output seal
Discussion in 'Dozers' started by 02Dmax, Feb 14, 2016.
  1. 02Dmax
    02Dmax Senior Member
    Dec 5, 2007
    666
    MO
    D7G 92V prefix.
    I had the torque out of this thing a few months back to replace the rear main seal that was letting engine oil transfer. Ever since then it has been blowing out the seal at the output yoke. I've replaced the seal 3 times and also replaced the yoke. I'm assuming I boogered something up when I had the torque out but not sure what. I didn't dismantle the converter at all. Just pulled it off, cleaned it up, and put it back on. Any ideas?
  2. Nige
    Nige Senior Member
    14,516
    Did you by chance take any TC pressures while you were working on it..?
  3. oldirt
    oldirt Senior Member
    Apr 22, 2009
    504
    iowa
    converter drain pump failed or worn out?
    is the the same tractor you r&r'd the final a while back?
  4. 02Dmax
    Dec 5, 2007
    666
    MO
    No, I haven't checked any pressures on it.
  5. Bob/Ont
    Bob/Ont Senior Member
    Sep 19, 2012
    1,605
    Ontario
    Might have a broken cast iron sealing ring near the back of the torque. Need parts pic to tell.
    Later Bob
  6. 02Dmax
    Dec 5, 2007
    666
    MO
    Ya, I went through one of the finals about a year ago.
  7. 02Dmax
    Dec 5, 2007
    666
    MO
    When it goes out its a severe leak. It's actually blowing the the lip of the seal out of the tin case of the seal.
  8. Nige
    Nige Senior Member
    14,516
    So it's not blowing the complete seal assembly out of the housing..?
    Genuine Cat seals or "will fit"..? Just to rule out a possible material issue.
  9. Bob/Ont
    Sep 19, 2012
    1,605
    Ontario
    The cast iron rings hold the charge inside the converter. If the rear one breaks a lot of force will be on the back seal.
    Later Bob
  10. Nige
    Nige Senior Member
    14,516
    Bob, Are you talking about the 2 metal sealing rings #4 in the diagram below...?
  11. Bob/Ont
    Sep 19, 2012
    1,605
    Ontario
    They might be the ones Nige, could you show me a pic of the shaft Please?
    Later Bob
  12. Nige
    Nige Senior Member
    14,516
    This is the best I can do for the shaft .......
  13. Old Magnet
    Old Magnet Senior Member
    May 11, 2010
    1,536
    Corralitos, California
    What leaks past those rings is open to the housing.
    The diagrams are for D6C but the G is the same.
  14. Bob/Ont
    Sep 19, 2012
    1,605
    Ontario
    What is #6 in the last pic you posted Nige? Was looking for a shaft ring but can't see it on OM's pic's. Failing that it might be a plug left in a cooler line forcing the pressure up to inlet relief setting.
    Later Bob
  15. Old Magnet
    May 11, 2010
    1,536
    #6 is a split metal ring. Looks to be retaining ring for bearing race #5
  16. Nige
    Nige Senior Member
    14,516
    OM, It is a split metal ring, but it doesn't retain the bearing, in fact it's a split ring rotating shaft seal.
    Bob, Here's an illustration of a TC from a D6R that uses the exact same 9M-2008 split steel ring seal that is used in the OP's 92V-prefix D7G.
  17. Old Magnet
    May 11, 2010
    1,536
    OK, I see it in my D6R parts manual. Called out as a ring-metal seal. Looks like that could be the culprit if damaged.
  18. 02Dmax
    Dec 5, 2007
    666
    MO
    Genuine Cat parts. I do believe I put a Cat Classic yoke in it though.
  19. Heavey Metal
    Heavey Metal Well-Known Member
    Sep 14, 2013
    148
    Texas
    Might as well overhaul the converter
    If you need more convincing do the pressure test and a stall spilltest and see how much oil its making.
  20. tctractors
    tctractors Senior Member
    Oct 9, 2007
    2,008
    Worc U.K.
    If the seal is blown don't bother with any pressure test just move on to the next point, strip out the converter as its going to have problems, often the shaft can move out of the converter towards the tran's due to thrust wear eating into the S/Pump drive gear face, this puts 1 of the steel seals outside the location, anyhow its going to need a full strip out.
    tctractors
    p.s. remove the S/Pump before the cover is pulled.
