D7G 7MB serial no
rollerman
Brisbane
mechanic
Can any one tell me if a 10Z serial no. 3306 diesel will go in a 7MB series 7G and what changes will need to be made to it to runn @ the 200hp setting.........rgrds, rollerman
According to what I can see the original engine for a 7MB-prefix D7G is a 3306 of 10Z prefix.
However here's the kicker. There are over 100 different arrangements of 3306 machine engine alone,and that's not counting industrial and genset applications.
If you have a specific 10Z engine in mind to go into the tractor post the Serial Number here, also post the Serial Number of the engine that's in it now.
rollerman
Brisbane
mechanic
D7G ser # is 7MB02959. original engine ser # is 1TF03652. I am proposing to fit serial # 10Z10185 cat 3306. What changes do i need to make for it to go straight in ? and at the 200hp setting ?
rollerman
Brisbane
mechanic
Also, what modifications/changes would neeed to be made to a 7JB04250 serial # 3306 engine to go in the same machine below ?
Cmark
Interesting.
(As you can see Nige,) SIS shows 7MB2959 as a D7G 1997 build, but my old skool serial number index shows 1984 build with a 44V engine. What little information there is gives us a transmission serial number of 7KA7650, but the only option for this tranny in a 7MB is for a series 2 5000-up serial number.
1TF comes up as a 3306 vehicular engine from 1987 and both tractor and engine were made in Indonesia.
7MB should be similar a 65V or 92V, so I'm going to take a stab at 4N4506 being the correct engine arr for this machine, and say that the 1TF isn't the correct engine.
CM, if you check out on SIS for 7MB1-5000 there is almost no information at all. Interesting though is that if you simply put 7MB into SIS and click on product structure you are faced with 3 options; 7MB1-Up, 7MB5000-Up, and a 3rd one that is a cross-reference listing of engine arrangements from "PTNR" to Mossville/Decatur-built engine product (I assume PTNR refers to an Indonesia build) for 1TF to 10Z prefix engines for a D7G. The problem is that in the list for D7G the engine Serial Numbers jump straight from 1TF3639 to 1TF3663, no 3652 listed.
rollerman
Brisbane
mechanic
Thanks Nige and Cmark, try engine serial #1TF06352.....there is a possibility that it is not the original engine. ARR # is 1W0543......however my problem is I have these two[2] replacement engines [7JB@ 300hp or the 10Z @170hp] ...........what things do i need to do to them to slot them in @ the 200hp setting.......application of tractor is general logging work
Interesting.
rollerman
Brisbane
mechanic
thanks Nige, yes, engine arrangement # is 1W0543 on the plate......what do i need to do to 170hp[10Z] and the 300hp [7JB] to make them work in this tractor ?
Your 2 possible replacements are no problem but I'm having trouble tracking down the details of the original engine S/N 1TF03652. Is there an Engine Arrangement Part Number listed on the Serial Number plate ..?
Cmark
It looks like 10Z10185 is also a 1W0543 arr from a D7G, so if your original engine is arr#1W0543, the 10Z should drop straight in.
Have you seen a plate on either engine that makes you think they are different horsepowers? I can only see 3 test specs for that arr# and they are all around the 200hp mark.
Have you looked in the cab for the original serial # plate riveted in there? It may be a bit battered, but if you can read it it will tell you the serial and arr # of the engine the machine was originallly shipped with.
rollerman
Brisbane
mechanic
Cmark, will a 7JB04250 arr 6C2231 drop straight in to original engine arr # 1W0543, horsepowers aside
Cmark
At first glance, no. This list shows what has to be changed. It looks a lot, but sometimes the difference between say the front gear groups for example may only be a couple of upgraded bolts. If you were serious about using this particular engine, you would have to sit down with the two parts books and go through the listed groups and see what the differences were.
TO CONVERT BASE ( 6C2231 ) TO COMPARISON ( 1W0543 ) REMOVE/ADD TO BASE
LINE IND REF NO QTY DESCRIPTION SVC SET TYPE Display Note BASE COM
ADD 1M-2902 1 CHART-INFO N MISC REF
ADD 1W-0541 1 TURBO GP N PTS-LIST L
REMOVE 1W-3802 1 FASTENER GP N PTS-LIST F
REMOVE 1W-4410 1 DAMPER GP N PTS-LIST F
REMOVE 1W-4486 1 FASTENER GP N PTS-LIST L
REMOVE 1W-4563 1 GEAR GP-FRONT N PTS-LIST F
ADD 1W-5634 1 GEAR GP-FRONT N PTS-LIST F
ADD 1W-7120 1 LINES GP-AIR N PTS-LIST L
ADD 1W-7733 1 DAMPER GP N PTS-LIST F
ADD 2P-6122 1 HOUSING GP-FLY N PTS-LIST G
ADD 2P-6152 1 PAN GP-OIL N PTS-LIST H
REMOVE 2P-6224 1 SEAL GP-CSHAFT N PTS-LIST D
ADD 2P-6226 1 SEAL GP-CSHAFT N PTS-LIST D
ADD 2P-6493 1 GAGE GP-O LEVEL D PTS-LIST H
REMOVE 2P-6528 1 COVER GP N PTS-LIST F
ADD 2P-6530 1 COVER GP N PTS-LIST E
ADD 2P-6573 1 MANIFOLD GP-EXH N PTS-LIST L
REMOVE 2P-6574 1 MANIFOLD GP-EXH N PTS-LIST L
REMOVE 2P-6855 1 FILLER GP-OIL N PTS-LIST J
ADD 2P-7747 1 SUPPORT GP-ENG N PTS-LIST F
ADD 2P-8160 1 GEAR GP-REAR N PTS-LIST G
ADD 2W-0106 1 LINES GP-TURBO N PTS-LIST L
ADD 2W-0259 1 PUMP GP-GOV& - N PTS-LIST M
ADD 2W-0713 1 PUMP GP-F PRM - N PTS-LIST M
ADD 2W-0851 1 LINES GP-DRAIN N PTS-LIST M
REMOVE 2W-1605 1 LINES GP-DRAIN N PTS-LIST M
ADD 2W-6779 1 LINES GP-WATER N PTS-LIST K
ADD 2W-9323 1 FASTENER GP N PTS-LIST F
REMOVE 3N-2884 1 PULLEY GP N PTS-LIST F
REMOVE 3N-2886 1 ADAPTER GP-SEAL N PTS-LIST F
REMOVE 3N-2898 1 GAGE GP-O LEVEL N PTS-LIST H
REMOVE 3N-2899 1 PAN GP-OIL N PTS-LIST H
ADD 4N-5162 1 COVER GP N PTS-LIST F
REMOVE 4N-8267 1 AFTERCOOLER GP- N PTS-LIST L
ADD 4W-1339 1 CONT GP-F RATIO N PTS-LIST M
REMOVE 4W-1876 1 PUMP GP-F PRM N PTS-LIST M
ADD 4W-4451 1 COOLER GP-BASE& N PTS-LIST K
ADD 4W-4452 1 COOLER GP-XMSN- N PTS-LIST K
REMOVE 4W-6157 1 LINES GP-WATER N PTS-LIST K
REMOVE 4W-6309 1 COVER GP N PTS-LIST G
ADD 5M-8212 1 LUBRICANT GP - N PTS-LIST P
REMOVE 6L-4502 1 PROD MARKING SY N PTS-LIST P
ADD 6N-1268 1 FILLER GP-OIL N PTS-LIST J
ADD 6N-1393 1 FASTENER GP N PTS-LIST H
REMOVE 6N-8326 1 LIFTING GP-ENG N PTS-LIST E
REMOVE 6N-8492 1 LINES GP-WATER N PTS-LIST K
ADD 6N-8870 1 LIFTING GP-ENG N PTS-LIST E
REMOVE 7C-0953 1 LUBRICANT GP - N PTS-LIST P
REMOVE 7C-2989 1 TURBO GP N PTS-LIST L
REMOVE 7N-0744 1 SUPPORT GP N PTS-LIST F
ADD 7N-1342 1 COVER GP N PTS-LIST D
ADD 7N-2887 1 PULLEY GP-CSHFT N PTS-LIST F
REMOVE 7N-3496 1 FLYWHEEL GP N PTS-LIST G
ADD 7N-9589 1 TRUNNION GP-ENG N PTS-LIST F
REMOVE 7W-1324 1 COOLER GP-BASE& N PTS-LIST K
REMOVE 7W-7899 1 PUMP GP-GOV& - N PTS-LIST M
REMOVE 8N-1167 1 LINES GP-TURBO N PTS-LIST L
ADD 8N-1868 1 FASTENER GP N PTS-LIST L
REMOVE 8N-2322 1 HOUSING GP-FLY N PTS-LIST G
REMOVE 8N-2582 1 LINES GP-AIR N PTS-LIST L
REMOVE 8N-3163 1 COVER GP N PTS-LIST D
ADD 9S-5784 1 FLYWHEEL GP N PTS-LIST G
rollerman
Brisbane
mechanic
original engine # 1TF06352 arr #1W0543.........proposed engine is 7JB04250 arr # 6C2231 .............300hp down to 200hp
Confirming what CM has posted .................
Of the 2 possible options for replacement the 10Z engine is by far the easier to install.
Your 10Z10175 engine was originally installed in a D7G Series II Serial Number 65V05844. The Arrangement of 10Z10175 is 1W0543, exactly the same as the Arrangement of your existing engine 1TF06352. Therefore by the book 10Z10175 should drop straight in with no need for physical modification, but without being able to compare the 2 engines side by side it's difficult to confirm. However 1W0543 engine arrangement has 3 possible Test Specs, the one you want for your D7 is 0T4784. This produces 217 Nominal BHP @ 2000 RPM with 675ft.lb of torque at 1500 RPM. A good fuel injection shop is what you now need to set up the governor and fuel pump, or at least to check that they have not been "Adjusted" from the standard setting. If you want to PM me with an e-mail address I can send you all the details of governor settings, fuel pump, etc.
