texaschad25
A few weeks ago, I had 2 O rings leaking between the pump and two of the lines, so I decided to replace all of them. When I pulled the cap housings from pump, each individual nozzle came out with the cap. I replaced the orings, but I apparently don't have the nozzles set correctly. The dozer cranks and runs, but the engine is slow to accelerate and doesn't seem to obtain full rpm with the throttle wide open, and has a slight miss. When the deceleration petal is fully depressed, the engine will idle down nearly to the point of stalling. Can someone tell me the correct way to reset these so that I can have my old powerful 7E back? Thank you!
