D7 17a direct start seller on amazon
ZGrant231
Oregon
I have recommended several installations for this unit but it needs a RH helical drive gear.View attachment 236556
Thanks for the heads up old magnet.
Alot of these sellers aren't very helpful and just reply..."see description" "fits D7 D8 D9 conversion"
I wish the links that you've recommended in the past were still good.
So it looks like I need a 11, tooth RH helical drive gear 50mt?
ZGrant231
Oregon
12338 seems to be
ZGrant231
Oregon
Pony threw a rod so that's my excuse to try a starter if I can find one.
Old Magnet, If you were looking to source a starter for this 17a, where might you look?
Old Magnet
Corralitos, California
Being pretty familiar with the 40,42,50 MT starters I would acquire the necessary drive end housing and helical drive to convert most any 50MT starter for the 17A application. The drive end housing/adapter is probably the most challenging to find. It is an aftermarket part usually labeled J&N 371-12144.
Nothing wrong with the Rareelectric package if you get the right drive. Also probably cheaper than purchasing individual components.
Andreas Jung
Vor dem Weißen Stein 21 D-72461 Albstadt
Driver Solutions Specialist
Yes, exactly.
If you are really want purchase helical driver gear box then i can suggest you a better product manufacturer company "Rehfuss", who are able to deliver high quality and efficiency custom-designed helical gear box worldwide. They deliver their excellent services since 1951.
There are some characteristics of Helical Gear Box below-
  • Optimised size/performance ratio
  • Highly efficient and low-maintenance
  • Designed for permanent operation under rough conditions
  • Housing produced from high quality grey cast iron with rugged walls
  • High axial and radial forces on the output shaft are permitted
  • Extremely torsion-resistant
  • Hardened helical gears produced from high quality steel with precision ground tooth profiles
  • Diverse attachment options
    Thankyou!
