D6r ac
kshansen
Central New York, USA
Will this help?:
D6R Refrigerant Capacities
D6R
1RW1-Up ... 1.6 kg (3.5 lb)
2YN1-Up ... 1.6 kg (3.5 lb)
3ZN1-Up ... 1.6 kg (3.5 lb)
4FM1-Up ... 1.6 kg (3.5 lb)
4HN1-Up ... 1.6 kg (3.5 lb)
4JR1-Up ... 1.6 kg (3.5 lb)
4MN1-Up ... 1.6 kg (3.5 lb)
4TR1-Up ... 1.6 kg (3.5 lb)
9MN1-Up ... 1.6 kg (3.5 lb)
9PN1-Up ... 1.6 kg (3.5 lb)
4WR1-Up ... 1.6 kg (3.5 lb)
5LN1-Up ... 1.6 kg (3.5 lb)
td15c
IL
kshansen thank. I put a new pump condenser and receiver drier on it. I put in 50oz or and had 20psi on low side and 200 on high at 78degs. has cold air out the vents. I didn't want to over charge. looks like I can add a few more oz. thanks again for the info
td15c
IL
yes about 3hr let it sit over night held vac added 8oz of pag45 oil
Dickjr.
Kentucky
You put a new compressor on? Does the drier have a site glass? They told me when I replaced my compressor on my D39 that as soon as then sight glass went liquid that was enough. suction pressure was about 25 psi. I was told that was fine even though the evaporator should freeze that all the heat off the machine would prevent this. At the same time the head pressure would be a little lower so the compressor would live longer. Its been over a year and it will blow 48* out the vent.
Cmark
In the last ten or so years I don't think I've seen a new compressor which doesn't come already filled with the correct amount of oil.
jughead
soddy-daisy tn.
retired
dont know why people insist on pag oil. last i heard ford had done away with it. untill i retired i used ester oil with great results.
td15c
IL
cmark its a aftermarket pump so pulled the plug to see what was in it not much. the pump that's in it calls for 300cc or 10.14oz on the label. so because I replaced the condenser and dryer thought 8oz would be safe and not overfill. jughead. Sandin calls for pag 45 for that style of pump. I don't no much about ac just try to keep my own stuff going
