serial DJA01031
i noticed with the blade lifted up it falls down, slow enough that you have to be watching for it. but it does drop. what is normal for blade drop ?? where do i look for the problem???
You have a percentage of drift but its not a lot like o.03 to 0.05 would take a while to drift down I would have to get the percentage Monday moring when I get to shop to be exact.......I would leave machine blade up during lunch and mark space on cutting edge measure ground to bottom of cutting edge both sides see how much it drops …
I would also get a laser temp gun to measure heat in cylinders after you have ran it 5 or 6 hours ..
Hydraulic bypassing packing creates heat and one cylinder would be hotter then the other ….
I would leave machine blade up during lunch and mark space on cutting edge measure ground to bottom of cutting edge both sides see how much it drops ..
both cylinders are working together so one might drop a lil more then other and that would be cylinder I would tear down and if I saw damage to seals or packing. I would repack both sides
