D6K2 drive spocket tighten procedure
I hope you're using all new hardware. This from the Service Manual - "Note: Do not reuse the sprocket hardware. The sprocket hardware has been stretched from the previous torque operation and can lead to premature loosening and hub damage. Always use new sprocket hardware and tighten to the required torque."
1. Lubricate bolts, nuts, washers with SAE30 oil. (not just the threads)
2. Torque bolts to 111 ± 15 lb ft starting from the centre of each segment and working to the ends.
3. Tighten bolts an additional 1/3 of a turn in the same sequence.
allen lafrance
Quebec,Montreal
mechanic
Yes all news parts and bolt etc thanks for help
