tracksfan
my D6H ser#4RC1088 trans oil level is doing something odd. after it sits unused for a couple days the oil level on the dipstick, cold oil and engine off, is way low, about 4 gallons or so. When I start it up and get it to operating temp its within the high and low marks for engine at low idle and warm oil. When I shut it down and come back the next day it reads between the marks for cold oil and engine off, let it sit for a few days and it reads low again. so where is the oil going?
Can it be drawn slowly into the torque somehow when the engine is off?
Can it leak from the trans case into the sump? (where the trans clutches are) not sure if I'm calling these compartments the correct name. When I open the back cover on the trans the clutches are submerged about halfway under oil. Does anyone know if this too much oil around the clutches? Is the scavenge pump suposed to keep the oil level drawn down to the bottom of the clutches?
This is got me scratching my head in puzzlement
