D6C won’t move
perkin
Saskatchewan
I’m trying to fix a D6c that won’t move I cleaned the inlet screen and changed the filter I have 350psi at the filter and 100psi at the speed clutch and basically nothing at the directional clutch port I took the speed clutch/directional clutch valve off and found a spool that blew apart so I changed the spool and still have the same pressure and won’t move where else can I check I’m thinking it’s a relief valve that splits to the torque but don’t know where it is or how to check
If you need full pressure testing procedure post the full S/N and I or someone else can upload that info.
See if this gives you any information that helps: attached file
  • POWER SHIFT TRANSMISSION D6.pdf
