kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,187
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
450 to 475 seems ample on a working engine as long as it puts out ample power. A worn in engine has less parasitic loss of power and can make more power than a fresh tight engine.
Also in the case of this particle engine the major concern I believe was the chance of a bent rod causing a low compression reading on one cylinder. So being they were all rather close to one another that does not appear to be the case at this time.
With all the variables involved I can understand Cat not wanting to publish hard and fast specifications as some owners would be trying to make all kinds of warranty claims if an engine was 5 psi lower than some specification.
