Merv, I would have rebuilt about 60 D6C/D final drives plus or minus a few that I just pushed/pulled for customers, so I have had plenty of looks inside the dead shaft hole, a few have been sorted by very impressive enginering skilled people, needing loads of money to sort it, other times just fitting a new shaft beaten in with some of "mama's special cream" with the castle nut dogged tight then drilled and repegged, has set the cure on this item, I have had a few of these shafts go in a bit off spec' but you can sort it on the adjuster hub, dont think I am a patch up man as I only do what I can for the man paying the coins, if things are tightfor the customer I can get him back earning, the shaft will never turn again I am confident???, as a note I always pull D8H/K dead shafts from their perch when doing F/D rebuilds, as they get clogged up with chunks of iron in the oil feed bore, its a shame the D6 etc tractors never had dead shafts bolted in like the larger tractors.
p.s. Duo-cone seals are very forgiving. tctractors
