tctractors
Twisted, I have adaptors that bolt on to the end of the hub using the 8 holes, this location is usualy used just to pull off the sprocket, the adaptor that screws onto the big C spanner style nut that made you "bark" some is the location that I use to press things back together, its all to do with the cylinder stroke of the 100 ton ram that you have, the standard travel is usualy around 6" of the rod, I would think 8 bolts ( use capscrews as they are good spec) should take the loading then you need the ram rod to be pinned to the end of this bolted on adaptor, the pin needs to be the correct item or something well-hard, anyhow this has to match up to the outer pushing sleave so as to give you the ability to pin the ram through the outer press sleeve into the inner bolted on bit with enough ram travel (Rod in) to press up the components, there is a fitting that goes against the cylinder press area that also locates into the press outer sleeve, if you can understand that you might be from Mars? years ago Komatsu used keys in the hubs not splines they called them Feathers and I never had the correct adaptor to press things back together, so I welded the big C spanner nut to a made up press adapter and used that, I told the owner the nut was worn out so he bought a new 1 without any qualm, anyhow I used this welded up gizmo on loads of shovels etc untill I bought a ruck of Komatsu tooling, I then painted up the welded up thing and sold it to a Polish truck driver.
tctractors
tctractors
