Northpoint
I noticed a post on here of a guy just changing everything and still had the same problem after parts changing.If I got it correctly , u had the brake/clutch valve assy off the tractor and found no evidence of a problem? and still the right and left side of this dual valve system behaves diff and sound to be the problem in your dozer?
This weekend i plan to look a my dozer, and the idea was to remove the TXM pump and send it for testing and repair if needed, but in this case i´ll also look at the priority valve pressures and the Brake clutch Valve system to see if it mimics your finding.
As i mentioned before, i´ve seen people complaining of this very same problem in this era machines here and other forums, with apparently no solution.
Then he either still hasn't fixed it or he fixed it and didn't post what his findings were. Which we all would be curious.
The main thing to do before anything is check pressure on the priority vavle at operating temp low and hi idle, and that will direct you to where to start looking as I stated in my post above.
As Mobiltech mentioned above it's probably the steer clutch's, and he had that answer after I mentioned my priority pressure went up when I pulled either of the steer levers. Well that wasn't hard to figure out after I mentioned that.
But I like to be sure myself and found a way to test which steer clutch side it is, maybe somebody knew how to test it but nobody posted how to. So my answer is Your Welcome!
Good luck finding your problem.
