buddfalen, on the overhaul it all depends of course, to drop this thing off with a mechanic and have an inframe done with a head, final rebearings with seals and clutch and brake frictions, trans done with frictions and seals and bearings it will hit $20,000 easily, the last trans in a d5h i did (look under shop talk "all in a days (or two) work pictures) was quoted at around $16,000 that was just rebuild did not include r&r or torque, it had some hard parts failed in it. don't give up on a bad inspection just use it to negotiate with, you may not find a d5h that doesn't need some sort of repair..............theironoracle
