Hello, I need a bit of advice from people with experience. I've got a 1972 d5 (54j powershift) and have recently been "doing it up". The problem with the steering brakes are minor in that both sides seem to work fine when pulling the lever's, right side works fine when using the brake pedal and the left side works about 80% of the time when using the brake. Sometime's it just doesn't want to engage on the left hand brake.
Before I bought this machine, the left side wasn't working at all.
I've just had the back end off to give us full access to the brakes. There was a lot of old oil and grease in the left hand side brake area. Maybe 2-3 litres???...I drained out all the old muck and pressure cleaned it out. The mechanic that I had working on it adjusted both sides and said he didn't really need to adjust it much...we had the inspection plate off the steering clutches and both pistons seemed to be working fine and letting the oil in and engaged the arms equally on both sides. There would have been at best guess about5-6mm of lining on the brake bands themselves. We then eventually raised the machine on it's blade and rippers and both sides seem to engage ok. Once the machine had been finished and I was able to test it out in the dirt I realised that whilst it was much much better but not 100%.
Our theory is that perhaps it is simply that the brakebands have been impregnated with oil and crap over the years and so were slipping from time to time and not engaging. Short of pulling themout I would realy appreciate input from those that can point me in the right direction. I'm not a mechanic...so be patient.
with thanks
with thanks
