kshansen
- Joined
- Mar 11, 2012
- Messages
- 11,165
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
I'm posting this for someone else, I suggested that he join Heavy Equipment Forums but thought I'd give a heads up here in case anyone wanted to get their thinking caps on.
I did tell him the first thing to do if he does come here for help would be to give the S/N and any work done before the problem showed up.
Hi guys I am currently on a mission base in Swaziland
Africa. The problem is a D5 Dozer with a Cat 3216 that runs
pig rich on cylinder number one . We have moved the
injectors and the problem stays on number one. Number one
injector is being fed 24 volts with the key off and 108
volts with the key on. All other injectors are 0 volts key
off everything is pointing to a bad ECM but it is very
pricey. Was wondering if anybody had any suggestions of what
else to check. Thank you for your time. We tested directly
at the ECM connector unplugged.
Ross MacPherson
Ross MacPherson
