06WranglerX
Good afternoon I have been reading up on threads for awhile as a guest but have my first question. I got the chance to use a D4H with a 6 way blade, 6 speed trans 3 fwd 3 reverse, while using it I went to adjust the angle of the blade from straight across to where I could put a small crown on what I was pushing (please forgive my lack of better terms) and the hydraulic hose let go, spraying the blade and front of the machine with fluid. I got the machine back to flatter ground and inspected hoping a hose had become dislodged upon closer inspection it appears the inner hard line cracked and split due to pressure.
The line that split connects from the cylinder to the large C carriage that holds the blade, I haven't done any hydraulic work but spoke with the owner of the machine who advised me to take the hose off and just bring it to him so he can get a replacement. How does one remove this from the machine? This would be your right side if your sitting in the operators seat, the side that goes to the cylinder seems to be straight forward but the side that enters the C channel is where I am lost. The hose is covered in a metal skeleton to protect against abrasion which goes to what appears to be a Brass fitting which covers the hard line inside that is damaged which I then assume is pressed down into the C channel.
I don't want to lose the inner hardline or have it break off then have to figure out how to get the broken end off I am hoping to cleanly remove this hose assembly in one piece to bring back to him. So if anyone can provide insight that be wonderful, I am handy with tools so I am not worried about taking some bolts off I just have never worked with hoses like this before.
