3rdGenDslWrench
- Joined
- Jan 9, 2011
- Messages
- 86
- Location
- MD
- Occupation
- Heavy Equipment Field Mechanic/ Truck Mechanic/Aut
Pwking I wish I could help you out a little further than this but I'm kind of at a whoa till I can get back into the shop and find some books on that engine. As far as taking the pump and the plungers out you need to Pin the pump on #1 TDC. And if you are going to remove the plungers inside of the pump when you put them back you need the Rack Centering Tool so all the plungers will put out the same amount of fuel. Now I'm not sure if the Rack center tool is the same but you should be able to take a 3/8 bolt, cut the head off and use the shoulder (no threads....the smooth part) to pin the pump on #1 TDC.
