Thanks for adding me. I have read many threads on here and they have been very helpful. I have a 1989 D4c Lgp 2cj00464 (made in Japan). This dozer was bought to do some work on my farm. The first thing I wanted to do was change ALL fluids and filters. In doing so I found 3 broken studs in the bottom of the left final drive. After looking inside with a camera I saw that they were from the bearing cage for the shaft. I decided to rebuild both f/d's. Everything is pressed and torqued back together according to Cat specs. My question is, the right f/d is very tight. It takes 80-100 ft lbs to turn it at the nut on the pinion flange. This is without oil in the case but assembly lube was applied to all moving parts. Gears, bearings, and seals are aftermarket from off road eq. Should I pull the case back off and try another new pinion? The left side turns easier but I reused the bull gear in it because it appeared to be fairly new. I have not dropped the steering clutches back in yet. Thanks, TWM
