D4 C first series, (I think) and serial number starting with 9BG ran out of fuel. I tried priming but no fire. Engine is 3204, serial number starting with 7YJ, injection pump, primer, oil and fuel filters are on the right side of engine, looking from the drivers seat.
I'm working on it for a friend and want to check the system thoroughly and check for blockage at tank and at primary pump. Is there a water trap drain or separator? If so, where is it located? any other tricks to get the prime again? It starts dependably previously,
Bruce
Bruce
