lizrad999
Good afternoon folks!
I recently picked up a Cat D3B dozer that was running poorly and smoking ALOT. I was told it sat a while and had bad injectors....nope.
I pulled the valve cover off since I am not familiar with these engines to determine injector type, and found two intake push rods bent and not touching rocker arms. Go figure. The associated valves were quite stuck.
Luckily I only ran it long enough to load and unload it. Not to say that the folks that "rescued" it from the estate it came from didn't do worse.
Yesterday I pulled the head and managed to remove the stuck valves. One of the valves was galled to what I originally thought was a valve guide, and the guide came out. Upon examination of the CAT parts diagram, and subsequent review of the other valve location, I have come to the conclusion that the 45V28529 engine did not have valve guides.
I also noticed the push rods appeared to be two different styles. Needless to say I am not the first person into the top of this engine, and for what I can only assume was also for stuck valves....which they destroyed the OG valve guide machined into the head, and subsequently bored it out and installed a sleeve. <sigh>
I found a pair of heads on FB that are fairly cheap, and need to know if they are interchangeable with the slight differences.
The greasy head is mine, and has 9L9270 cast into it. The head on the dolly is the one I can go get and seems to have 2W71?? cast into it.
I would much rather go back with a "unmolested head" if possible.
Soooo......are these heads interchangeable? Thanks in advance!
