NMBlackBetty
So we have an '86 Cat d3b (27y) serial. The track tensioner blew out. We're about 6 weeks away from rebuilding the entire undercarriage, from the chain/track down to idlers and tensioners. This blow out couldn't have happened at a worse time, it's 6 weeks to get all the parts as we had to order from many different places as a lot of the parts are "obsolete" from cat we've been told.
I was able to get a repack kit for the tensioner, but taking the track off right now isn't an option. The service manual says the "pin with a dimple" is the pin that will come out, but the entire track chain is so far gone, there is no dimple left to be found. When the new stuff comes in, I'm just cutting it off with a torch.
I've been told "unless you want to lose your head, don't take off the bolts that hold the spring under tension" so without doing that, I don't see any way to get the yolk out of the cylinder to repack it.
Hoping some of you guys who play with this stuff all the time can shed some light.
Photos attached.
Photos attached.
