just-a-mechanic
Hey guys I bought a new to me unknown year D31P-20.
I have videos and pictures to attach. But unable to at this moment. I will do so very soon.
questions:
I have a wet clutch/brake system, the manual says it’s supposed to be dry. That’s odd - I have a dipstick into the steering clutches cavity. So definitely wet.
The frame lists this as a D31P-20, not 20A. Anyone know the year of this? 96-97? Maybe?
The components of the clutch and brake assembly appear in pretty good shape. No brake band wear for the braking system and it appears someone recently replaced the brake lining.
my issue: clutch does disengage when trying to turn. This was confirmed. Brake will not apply to allow the machine to turn. Brake actuators extend variably as designed, depending where you position the control. (Pilot controls, manual) The pressure is approx 250/270 psi a bit low but good enough.
What is odd is the brake liner has been checked and it is over .25” of material remaining on the brake band. (Books says wear up to 4.6 mm I think, I Used a precision ground gauge block) The part number listed on the brake liner is -113, not 114 called in the manual. However it looks like it was just superseded.
All components look good. The brake band nut has been adjusted until it bottoms out, it never applies any pressure to the clutch assembly. So the brake band is too loose as it is assembled.
So I can not apply 350inlb of torque against the band, then looses 2.5 turns ti properly set it. As the band is never torqued.
I’ve been cross checking to see if the incorrect parts have been installed into this system. Seems like something is undersized in the wet clutch or oversized in the brake band.
What do you think?
questions:
What do you think?
