Back at the project generator. I have an 08 kubota D1105 Generator runs good at idle maybe a small amount of smoke but not easy to see. As i increase the load more and more smelly black smoke comes out getting thicker as the power demand increases. I know its way to much smoke has my garage full in no time when i really put a good load on it.
Pressure test shows cylinders are good and strong. I did a valve adjustment already.
I did have to fix the injector pump to get it to run it was gummed up. So i did take it all the way apart.
I know it means i am dumping to much fuel but is it an injector the pump or something else. What should i test and how do you recommend i do the test it?
Thanks again as always.
