Over here the mine operators have another way of solving it.
You keep a big steel ball with you when loading.
If you find a big boulder like these ones, you pick it up in the bucket and drop it on the boulder.
With a big front loader you have very presice controll of where it hits when u open the bucket.
Problem solved and no stop in production.
Only problem is if you load it onto the trucks, steel balls isn't popular in the maincrusher.....
Otherwise you have a big exc with a hydraulic hammer for the splitting of big boulders.
On a big dam i was working they loaded with a Le Tourneau, and had a Cat 350 with a hammer for splitting boulders. A rather big combination for that job. It had a quick coupler and loaded smaler trucks when not splitting rock..
Regarding the boulder on top of the truck, i beliewe it was on purpose.
Loaded like that u can drop it off without dropping the whole load.
But u can be unlucky and loose it on the road.
They might have a spot not so far away where they tipp the big ones.
U can also have them in front of the next blasting and have the moving rock from the blast destroy it. Moving rock in the blast destroy each other, and thats calculated in the blasting plan.
Cost u nothing.
