charles walton
My 230 Cummins has a fuel leak that appears to be coming from the crossover tube between the front and the middle head. Who can tell me what I need to do to fix it? Thanks in advance.
Thanks, I have been into one before but it was 10 years ago, I changed the injector o rings and I got it back together and it ran....b bu it took me a while.Maybe I can do this job a little quicker!First blow out or pressure wash it between the heads, If it has jakes remove them. Most of the time it will require one of the rocker boxes be removed, But if one crossover is leaking you may as
well do the other while you have the center rocker box out of the way. Then re-seal and run the over heads while your there. Should be a small cam but best check before you make a mistake
like someone else did.
I like to add a little hydraulic oil to the low sulphur fuel.Had that problem with my 250 last year. The rear one was no problem other than trying to get the screws loose with an impact driver. The front one had a lifting bracket in the way. I cheated and took a bolt out of each rocker housing. Then R&R crossover o-rings.
Now a truck with with a L10 pump has a leaking throttle shaft.
Had a lot of o-ring problems when low sulphur fuel came out. Is this a repeat with Ultra Low Sulphur fuel?
Would you,or anyone else that happens to read this, happen to have a part number or size number for the o-rings ?I inframed that engine in the early 90's with an aftermarket kit. Poor quality o-rings no doubt?
I wouldn't call it short........Nige, didn't we have a short discussion about low sulfur diesel?
You are referring, I assume, to fuel lubricity numbers..?
I am interested in the discussion you two had on that.That be the discussion.
I went by the Cummins dealer near me a while back and picked up a couple of o rings that were supposed to be this number and they look to be way too big. Do you know what the dimentions and what material is best for this that I can pick up maybe at Napa?I believe the Cummins part number is 152946 for o-rings. If my notes are correct.
