So as you can see we have a problem here..... This motor is in a Snorkel TB 66J lift. It was smoking really bad and determined that the #2 cylinder was losing compression. I figured it was a bad injector, but was quickly proven wrong on that! We removed the head and had it pressure tested, came back fine. I happened to notice that at the top stroke the #2 piston was about 1/8" lower than #3. Crazy, as big as these rods are that they would bend like that and still the engine runs without catastrophic failure.....
I was hoping to see if anyone has torque specs for this engine? I gotta order a new seal kit and rod Monday so it will be a few weeks before parts arrive. Any help would be great.
