I just acquired a 580ck that I am trying to do full rebuild of the engine and wanted to get advice on using the original block or trying to find another one. the block has a few small verical cracks at the top where the sleeves sit. i heard this is pretty common and should not pose a problem since the orings are at the bottom portion and the head gasket will seal the top. This seems to be ok, but the main concern I have is that at the front of the block there are two lower front mounting ears broken off where the block mounts to the chassis. It appears the PO left the bolts loose and the engine shook itself. I was thinking I could possibly use washers over what is left of the ears or maybe try building them back with weld. One of the top ears has a small crack, but it is not broken off. Looking around I found a used block for $1300, but who knows how much better it is. I got the backhoe for free and it came with a rear ganon
When I was a teenager I was given a Case VAC. The rear hyd housing had filled with water, frozen and cracked. My next door neighbor, a mile away, worked at a fab - machine shop. I still consider him a masters master. He said he wished he had the opportunity to learn under a great blacksmith. He showed me how to vee it out and weld a half inch at a time. Then tap on it with a slag hammer for at least five minutes. Come back tomorrow. That would be when he was back from work probably not the required time interval. I got in a hurry at the end and welded about an inch and a half. It popped and I had a new crack equal to the first.
He taught me more and I have picked up from others along the way. I have welded cast parts on top of an oil drain pan, cut off 55 gallon drum, with a screen over it. Put a big bag a charcoal in it first and get parts up to about 400 degrees first. You can weld a lot more at a time that way. Leave the part there to cool with the coals. Some folks make a sand pit. Through the hot part in it and cover it with sand. Leave it until tomorrow.
I welded a new starter ear on a 6.2 diesel. Actually a piece of square key stock cut to fit. Man had overhauled the engine and had it out of time. It broke one ear off the block and the starter noise in half. He had pulled the engine back out. It was fully assembled and we set up a torpedo heater blowing on it. Then welded a little at a time. Drilled out and threaded a new hole. An air needle scaler works better than a slag hammer.
Have been told and or read that nickle alone is not great in high stress jobs. Stainless can also weld cast but has its own evils. I welded the center section of a JD tractor axle with nickle, rosebud around, stainless, repeat, repeat, repeat. That also worked OK.
Traveling salesman came by once making great claims. I went and got some cast parts for a grain drill. He claimed it would work and we went on it. Hot heavy and no stops. Maybe 3 or 4 inches each weld. I bought a box of that high priced stuff. Probably the same stuff Nige posted for only twice the price. I thank I still have the box in my tool box. If I had a special job I would buy it again.
Mathew: Now through that block in the scrap and spend $1300. It is not worth investing all that time and money in a block with a high risk repair.
